LQQk here to see what I found, my 72
Is this the build sheet?
http://www.corvetteforum.net/c3/kim_mle/bsheet.jpg
Re: LQQk here to see what I found, my 72 (Ki m Le)
Looks like it could be, I think I can make out the words "corvette order" on there, so it probably is :cool:
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
looks like it to me :thumbs:
yes, that is the infamous "tank sticker." Yours looks to be in pretty good shape.
I have mine, but about a 4" diameter piece in the middle is still stuck to my tank. :cuss
Re: LQQk here to see what I found, my 72 (Jeff 6T9)
Re: LQQk here to see what I found, my 72 (SIGNGUY)
is this sticker accessable without removing the gas tank?
Re: LQQk here to see what I found, my 72 (QuickVet)
QuickVet,
No, it was not too bad. You need to remove the rear exhaust system, the spare tire carrier and drain the fuel for easy access. Also, disconnect the vapor vent, feed and return hoses.
The tank was held together by a bottom support bar (4 nuts, 9/16") and 2 straps (2 bolts, 1/2").
I'm going to coat the tank with the Eastwood tank sealer kit.
Hey Brian, I barely made it! See you soon at K-Mart 4/23/03?
