camaro 5 speed transmission
Will a mid 80's camaro 5 speed transmission fit in a C3 if so what bellhousing,clutch will work also what about speedometer and drive shaft?
Thanks ahead of time IETEK :D
Re: camaro 5 speed transmission (IETEK)
The speedo gear will most likely need to be changed since it is a different trans than the one in your car - you almost certainly will need to shorten the driveshaft.
Re: camaro 5 speed transmission (fauxrs)
Will they work yes, will it last long maybe.
They have a low torque rating so low you couldn't get a 350 Camaro w/ the 5 speed only offered it with the 305. If you wanted the 350 you had to get the the 700R4.
