Need info on 75 L-82
Anyone know what came in the 75 L-82's? Head type, CC ,valve size,crank & piston type, windage tray? etc.
Thanks,
Gary
Thanks,
Gary
Re: Need info on 75 L-82 (gtr1999)
Gary,
Take a look here, I list the config for the '73 L82. The 75 would have the same except for the exhaust (plus carb tuning and HEI ignition tuning which results in a lower hp rating for the '75):
http://www.corvetteforum.net/c3/vette73/compair.htm
tom...
[Modified by Tom73, 11:48 AM 3/17/2003]
tom...
Re: Need info on 75 L-82 (Tom73)
Thanks Tom, I didn't know if the L-82's came with a factory aluminum intake like the LT1 did?
Gary
Gary
Thanks Tom, I didn't know if the L-82's came with a factory aluminum intake like the LT1 did? Gary
The early L82's had iron intakes, same intake as used on the base L48. Later L82's (77 or 78 on) used an aluminum intake but all it did was save weight, was the same as the iron one.
The LT1 used a high rise aluminum intake which would not fit under the L82's hood. :)
tom...
Thanks again Tom :cheers:
Gary
Gary
actually i am running a highrise al. intake from a '70 LT1 on my '76 along with a holley 750 duel feed and drop base air cleaner with k&n filter and extreme air flow top, i have about 1 inch clearance to the hood.
thanx wade
thanx wade
