WILL IT FIT?
WILL IT FIT?
Hi everyone i was just wondering if i could get a performer rpm intake manifold to fit under my stock 69 hood? the carb i am using is a holley spreadbore double pumper with mechanical secondaries list number is 6210
oh and if the performer rpm will fit under a stock hood then how about the air gap rpm. the hood is just the sock hood that came with the 350 so if any one could tell me what my options are as far as manifolds go it would be greatly aprecieated
thanks! :seeya
thanks! :seeya
Re: WILL IT FIT? (Randexter)
I have a performer under the stock small block hood - no problem.
I have read on the forum that the air-gap will not swap in.
Perhaps with a lower dropped air cleaner base - you could make it work.
Good Luck. :seeya
Good Luck. :seeya
