POR-15 the Underbody? Color?
Guest
Posts: n/a
I took some SOS, grease lightening and a power washer and scrubbed down the frame and under body. Removed everything that's bolted to the frame, even the tranny cross member is lowered.. I'm going to paint the frame POR-15 semi-gloss black.. What color do you paint the underside of the seats? Also the back area where the diff. carrier goes.. right now it looks like a grey or pewter. I'm not so keen on painting everything semi-gloss black.. Besides, where the carrier goes it's fiberglass.. POR-15 works best on metal. so I might use up the POR-15 on the underseat but not in the back. Any ideas.. pictures.. I don't plan on showing the car with mirrors under it or anything but since I'm doing it... well you know.. :D
Also, do you paint the inside of the wheel wells? Spray Undercoat ?
[Modified by Koz, 8:34 AM 3/17/2003]
