Hooker Sidepipe Install Problem
Cruising
I have recently purchased the hooker sidepipes from Jet-Hot and I am having one heck of a time getting the sidepipe over the collector. I have applied anti-seize, but I can only get the pipe on about 2” before the pipe just refuses to move any more. I have hammered on it to no avail. Any ideas?
Thanks
Thanks
Re: Hooker Sidepipe Install Problem (71BigBlock)
how far is it supposed to go on?? i am planning to take mine apart soon but have not yet....i always thought they were only a few inches on anyway??
Cruising
Re: Hooker Sidepipe Install Problem (1bad69)
It is supposed to go on about 4", it will then line up the brackets on the sidepipe to mounting points on the frame.
2 inches sounds about right. Are you matching the mount bracket to the holes in the side of the frame or the bottom? The correct mounting point is to the holes in the side of the frame, under the rocker panels.
[Modified by 1979toy, 8:44 PM 3/16/2003]
I'm planning on purchasing mine next week? I can't offer any help yet. Take a pic of your problem I want to see what I'm getting into. I have a small block. Perhaps that will be easier. :smash:
I suppose getting a small block and another set of headers is out of the question. :lolg: :lolg:
Cruising
Re: Hooker Sidepipe Install Problem (1979toy)
Correct I am attaching the pipes to the side of the frame and I am literally 1" away from being able to get the bolt in the frame and onto the mounting bracket on the sidepipe, but it just will not budge any more.
I actually have removed the pipe to start over again somehow, so pics are not available until later tonight or tomorrow.
Re: Hooker Sidepipe Install Problem (74 vert)
When I mounted my jet hot coated sidepipe headers, I could not get then on either. I put wood on it and hit it a rubber mallet and wiggled it up and down and back and forth. I use anti-sieze,spit and sweat....
I finally used a flapper wheel on a drill and removed some jet hot coating from the inside of the tube and worked it on.
Neil in Tenn
Neil in Tenn
St. Jude Donor '09
The coating was so thick on the inside of my sidetubes I had to use a 3M abrasive wheel chucked in a die grinder and remove it to get them to fit properly. Anti seize will keep them from rusting at the union :cheers:
Cruising
Re: Hooker Sidepipe Install Problem (yellow 72)
Excellent idea thinning out the inside of the sidepipe, I actually thought about this, but was concerned about removining the coating, but at this point I'm willing to try this.
Did any of you guys buy the STS baffles? Do you think the baffles will be hard to fit in the sidepipes?
Cruising
Yes I purchased the STS Baflles and they just slipped in. Absolutely no problems with them fitting.
I had to have my side tubes swedged a little....then they fit fine. STS baffles are the BEST, BTW.
:yesnod: :chevy :chevy :yesnod:
