Making tach work for 72 w/ electronic ignition
Old 03-16-2003, 08:16 PM
cvettego
cvettego's Avatar
Default Making tach work for 72 w/ electronic ignition
We just had our ignition changed to electronic in our 72. Can anyone please tell us how to get the orginial tach to work or what year tach will work and fit into the orginial opening ? Thanks, Bob :confused:
Old 03-16-2003, 08:28 PM
74BBcherryred
74BBcherryred's Avatar
Default Re: Making tach work for 72 w/ electronic ignition (cvettego)
Hi Bob did you change your distibuter or did you put a conversion kit into the original distributer. Dave
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
A 1975 tach will fit, it is an HEI tach, good luck finding one. The only other alternative is to have your old tach drive distributor converted to HEI. Dave's Small Body HEIs will do the job for about $175.00
http://www.davessmallbodyheis.com
Or you can convert it yourself by putting in a Mallory or Crane ignition module.
Old 03-16-2003, 08:31 PM
trw
trw's Avatar
If you just converted your distribitor to electronic, the tach will still work.
But, if you changed the distribitor then it was 75 that changed to electronic tachs. I think the 75-76 tachs will fit.
Hope this helps.
Terry
Old 03-16-2003, 08:47 PM
cvettego
cvettego's Avatar
Default Re: Making tach work for 72 w/ electronic ignition (74BBcherryred)
HI Dave, We had the work done. He put in a new electronic distributor and changed the ends of our 8mm wires so they would work. Thanks, Bob
Old 03-16-2003, 10:45 PM
70ZZ3 96LT4
70ZZ3 96LT4's Avatar
You are pretty much out of luck in making our 72 mechanical tack work with the electronic distributor you had installed. Did your installer tell you the electronic distributor change out would not support a mechanical tach? About the easiest thing to do is buy a tach and mount it on the steering column. Another option is buying the electronic tach from a 75 or later Corvette with the same style tach and switch it out with your mechanical tach. Electronic ignition distributors with mechanical tach drives are also available.
Old 03-16-2003, 10:51 PM
wombvette
wombvette's Avatar
Default Re: Making tach work for 72 w/ electronic ignition (Smokehouse69)
Find a lot of used 75 tachs at the larger swap meets.
Old 03-16-2003, 11:04 PM
74BBcherryred
Default Re: Making tach work for 72 w/ electronic ignition (wombvette)
Hi Bob the electronic distributer i put in my 74 454 is an msd with the mechanical output connector for my factory spedo cable what name brand did he put in yours and does it have the threaded piece for your old cable to go on to Dave :grouphug:
Old 03-17-2003, 02:10 PM
cvettego
cvettego's Avatar
We will get the Vette back from the paint shop sometime this week ( I hope) and I'll look at it better and let you know just what it is. Thanks for everyones help. Bob
Old 03-17-2003, 02:34 PM
Togo
Support Corvetteforum!
Togo's Avatar
without taking the distributor out, how can you tell what kind is it (please don't tell me i need to take it out!!!) the GF has a 74 and the speedo needle is not only gone, but it starts at 100MPH as the zero point! and the tach also does not work! what color are the wires for the tach, and where is their exit point from the passenger compartment????
Old 03-17-2003, 02:44 PM
phoenix
phoenix's Avatar
Default Re: Making tach work for 72 w/ electronic ignition (85_togo)
I bought a used 1975 tach from a forum member. $100 well spent I think.
Old 03-17-2003, 04:05 PM
jackson
jackson's Avatar
Electronic tach from either 75, 76 or 77 vette will fit & work & look almost like original ... hardly anyone could tell ... only those three years. I got a good one off eBay for $50 ... but ya never know about eBay.
Old 03-17-2003, 04:12 PM
jackson
jackson's Avatar
Hi Bob the electronic distributer i put in my 74 454 is an msd with the mechanical output connector for my factory spedo cable what name brand did he put in yours and does it have the threaded piece for your old cable to go on to Dave :grouphug: without taking the distributor out, how can you tell what kind is it (please don't tell me i need to take it out!!!) the GF has a 74 and the speedo needle is not only gone, but it starts at 100MPH as the zero point! and the tach also does not work! what color are the wires for the tach, and where is their exit point from the passenger compartment????
74 came with mechanical tach ... driven by cable (like speedo) from a gear on distributor. Mechanical tach has only a wire to illuminate it. HEI distributor began in 75 along with electronic tach. 75,76,77 electronic tachs will fit dash of 68 thru 74 ... helpful when 68-74 is converted to HEI or other distributor lacking a cable drive for a mech tach..
To Making tach work for 72 w/ electronic ignition
Quick Reply: Making tach work for 72 w/ electronic ignition
