82 rear suspension question (Gymkhana?)
I have the following sway bar set-up
Front 1 1/4
Rear 1/2
I measured 3x
I also have a 9 leaf steel spring. I know 82s were supposed to come with a fiberglass rear spring.
What in blazes in going on under there!! :crazy:
Brent...
Front 1 1/4
Rear 1/2
I measured 3x
Brent...
Re: 82 rear suspension question (MN-Brent)
Sounds like Gymkhana suspension to me. The front sway bar is thick enough, and the presence of a rear sway bar indicates it. Not sure on the dimensions- it may be more accurate if you wrap a string around the bar, then take the measurement of the string(circumference) and divide by Pi to find the diameter. I would bet 1.125" front and 7/16" rear sway. Not SURE on that though, 82 expert should chime in.
The 80-82 Gymkhana cars had a steel spring instead of composite.
-Steve
-Steve
all FE7's had the steel spring. Check to see if you have aluminium strut rods, if you do it's original, if not someone either swapped the struts or replaced the spring.
Re: 82 rear suspension question (paul79)
Strut rods are aluminum!!! Thanks for the info Twinnie. Hope you dont mind if I use that name.
Also to Pacin and Paul, thanks for your replies.
Thats super cool!!! I just ordered KYB Gas-A-Just shocks through the Tire Rack via the forum ($29 each). I hope they match up well with the springs.
Its great learning something new about your car, especially when it goods news like this.
Brent...
Brent...
[Modified by Twin_Turbo, 4:57 AM 3/17/2003]
