SOOO close
Old 03-15-2003, 08:23 PM
Corz
Corz's Avatar
Cruise-In IV Veteran
Default SOOO close
i had just finished installing my lower a arms (and new springs) and i was putting my brake pads in when i look on the garage floor to see a puddle of brake fluid dripping from the caliper :cuss :cuss
i pulled the caliper off and it looks like the seals let go.. but i cant tell because i cant get the dust boot off. am i better off going to napa and getting a new caliper, or taking this apart and rebuilding it?
if anyone in CT has a passenger front caliper that is still good, I'd be more then happy to pick it up tonite :thumbs:
Old 03-15-2003, 08:57 PM
trw
trw's Avatar
Default Re: SOOO close (Corzvette69)
If they are new I would take it back. At least they will replace it with one that works.
Terry
Old 03-15-2003, 09:08 PM
Corz
Corz's Avatar
Default Re: SOOO close (trw)
i honestly dont know how old it is... could be 2 years could be 30 years.. i dont remember if i changed it or not
Old 03-15-2003, 09:15 PM
trw
trw's Avatar
If you shoot a little air where the brake line enters, and I mean a little, you should get the boot off.
If they are not SS you probably will have to much pitting to rebuild anyway. Depending on your goals, NAPA sells them for $65 exchange out the door.
Terry
Old 03-16-2003, 12:43 AM
PatG
PatG's Avatar
If they are stainless sleeved then get a set of zero tolerance o-ring pistons and rebuild. If not sleeved then get new calipers. Dont bother rebuilding with the OEM lip seal design. The dust seal will come of easily by prying with a screwdriver but you will most likely puncture the rubber boot.
Old 03-17-2003, 05:10 PM
GTR1999
GTR1999's Avatar
Received 2,587 Likes on 1,326 Posts
So, did you get the brakes fixed?
Gary
To SOOO close
Quick Reply: SOOO close
