Herbert Cams..
Herbert Cams..
I`m running with a Herbert cam,and its a Hydralic roller.Does anyone know if i need to use a Bronze distgear,or can i use the "normal" distgear?
I searched their site,but theres no information regarding that..Neither is there a Email adress.. :confused:
:cheers: :cheers:
:cheers: :cheers:
Re: Herbert Cams.. (BB wowbagger)
Some camshafts are not compatable with the OEM cast iron distributor gear. Basically a racing application where steel billit cams are used. The bronze gear will not hurt street engines and can help prevent unnecessary wear and cost around $40.00 :thumbs:
