ride height vs crate engine
zz430 clone is installed and running. Scary power! I removed all A/C componets when I did the engine switch. Also gave up the stock fan & went with electric and alum water pump. Now the ride height appears to be too high. Who make good lower springs? Who is VBP?
thanks
thanks
Re: ride height vs crate engine (jroyse)
Between the aluminum heads and the loss of A/C you probably are 350 pounds light in the front end. Look for springs from a car w/o Air Cond and see if the spring rate is different.
VB & P is Vette brakes and products.... http://www.vettebrakes.com/
I would suggest you go with the 550 springs, i think they are supposed to lower the car 2 inches. I currently have their 460 springs(which are suppsoed to lower the car 1 inch from stock) and I am going to have to cut them to get the ride height that I want. :cool:
