Dwell Meter recommendations
Anyone have any suggestions as to what brand of Dwell Meter to buy.
Most bang for the buck :yesnod:
Re: Dwell Meter recommendations (Stewart's74)
i dont remember the brand, but it was from Kragens. they have a timing light/engine analyzer in one. i think it was $180 but it does tach, dwell, timing, and the light will give you total advance also. very good unit, at least i'm happy with it 2 years old and no problems. the $180 one was the most expensive one, with the red rubberized housing.
Re: (MNJack)
Jack, do you have the Sears one? I saw they have 2. $29 & $49. I'll most likely go this route due to their return policy
I have a digital multi-meter designed for automotive use. It has a dwell funtction.
[Modified by silvervetteman, 4:46 PM 3/14/2003]
Dwell is measured in degrees. It is the number of degrees the points are closed. Because of the adjustment available the timing must be checked and re-set if needed after adjusting the dwell. Particularly after installing a new set of points.
[Modified by silvervetteman, 5:02 PM 3/14/2003]
