Will my rear end drop enough with axles on?
Will my rear end drop enough to get the crossmember off with the trailing arms and half shafts still on? There are no other connections besides those. An inch or two would be plenty, right?
Re: Will my rear end drop enough with axles on? (Schmucker)
The problem is the frame mounts extend an inch or two into the crossmember. That could be a lot of weight coming down pushing your trailing arms outward. Why not just unbolt the half shafts?
Re: Will my rear end drop enough with axles on? (74jack)
Good luck dropping the cross member. /evil laugh on...
You may want to do a search for others who have dropped the crossmember and difficulties and tips they had.
Re: Will my rear end drop enough with axles on? (Maurice)
Yeah, I know. That is why I have a 4 ft pry bar laying on the shop floor :D I need to make a custom crossmember that isn't as tall so my coilover conversion works better.
