Alum. heads and stock iron manifold question.
Have finished installing alum. heads but for the time being going to keep org. rams horn exchust manifolds. Would you install gasket or go metal to metal?
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Alum. heads and stock iron manifold question. (82zoom)
I used gaskets on mine, along with some Hi-Temp RTV. It's been about 3 months and 1500 miles and the gaskets are holding up fine, no leaks.
I'm not a expert by any stretch..but was currious to know why you would want to choke your new heads with stock ram horns? Why not headers?
Currious minds want to know! :confused: :confused:
Eddie
Eddie
Re: Alum. heads and stock iron manifold question. (Budman78)
Gaskets.....Weird combo though.
You have to use a gasket when using iron manifold with aluminum heads due to the different expansion characteristics of the metals. Buick did this on their all aluminum V-6 and V-8s in the early sixties (and it would have worked much better if they had used a more robust casting at the down-pipe. These manifolds are so notorious for breaking at the flange that most muffler shops wouldn't touch them, or at least not without the customer's signed understanding that the flange would likely crack) so it's not exactly without precedent.
Re: Alum. heads and stock iron manifold question. (gerry72)
no gaskets on my Brodix's. and lots of miles. My only problem was when I put the al heads and mainfold on they disapated a lot more heat alot more quickly and buble the piant on my hood.
Re: Alum. heads and stock iron manifold question. (Silvr77)
Eddie
Eddie
I know there were no gaskets on org. block and manifolds but didn't know if there should be when you mix and match.
Thanks for info. guys
