Synthetic Oil and Cams, Comp Cams Tech Advice
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Earlier in the week, someone posted that Crower did not recommend synthetic oil for their cams. I asked CompCams what their feelings were on synthetic oil.
The response was:
The only time I dont recommend synthetic is when running a roller cam because often the oil is so fine the lifter wheel will slide across the lobe instead of spinning resulting in a failure.
Seems to make sense.
Hope this helps. :cheers:
The response was:
Re: Synthetic Oil and Cams, Comp Cams Tech Advice (joeveto)
Wow, that's funny because crower made it sound like it was worse to use on flat cams, and rollers were OK. :confused: I think the general concensus is that synthetic is good for motors. Some engine builders of severe performance engines don't like it, and I think that is crowers angle. I am curious what monty, and merlin are using? Rollers are what all of the new cars have that come filled with synthetic. Thanks for posting that. :cheers:
Re: Synthetic Oil and Cams, Comp Cams Tech Advice (boredsoIstrokedit)
Re: Synthetic Oil and Cams, Comp Cams Tech Advice (Cookwithvette)
C5 uses a roller cam and comes from Chevy with Mobil 1 in the crankcase.
Ken :cheers:
The response was:
The response was:
:confused:
