AFR 195s on order, will be here next week!!
FINALLY!
Found them on the shelf at Herbert Performance, they should be here next week.
Along with the heads, I have Comp ProMagnum 1.6 roller rockers on the shelf at home, along with an Edelbrock RPM AirGap. I think I'm going to go ahead and pick up a Comp 274XE to better match the rest of my components, right now I'm running a 268H and it may be a little small for my other stuff.
Whaddya think?
Jeff
Whaddya think?
Jeff
Re: AFR 195s on order, will be here next week!! (no_radio)
I think you are in for all kinds of fun. I would agree with switching to the 274XE. I really like mine. I'm running Rhoads lifters and I think it's doing pretty good. You should get a pretty good hp jump with all those parts. Are you going to check the valve tip to rocker meeting point? With 1.6 ratio rockers you may need longer pushrods. The overall geometry may change quite a bit with new heads and rockers. New parts are so much fun, enjoy, enjoy.
