OFFSET TRAILING ARMS BEST PRICE?
Here is yet another trailing arms question. I wish to purchase offset trailing arms so I can get 17'' wheels. I like cragar 's 61 series wheels. Which vendor sells offset trailing arms at a reasonable price? thanx in advance.
Location: The cure for the blues is eight cylinders roaring
Re: OFFSET TRAILING ARMS BEST PRICE? (Oldguard 7)
You dont need ofset arms to run 17s unless you plan to go with much wider wheels.
Re: OFFSET TRAILING ARMS BEST PRICE? (PrarieShark)
17"x8" with a 4" backspace should work fine as long as the wheels clear the calipers, if they don't you may need a small spacer. Shouldn't need offset T/A's unless you going with 9.5"+ wide wheels. If you want/need offset T/A's though, then Vette Brakes or Van Steel will be the best, and both are supporting vendors :cheers:
[Modified by Ryan77, 5:56 PM 3/13/2003]
i have 17x9.5 zr1 wheels on my 79 with stock trailing arms and "vette brakes" spacers.
never had any trouble with them.
http://www.boomspeed.com/jrodd/racevette2.jpg
[Modified by JRODDVETTE, 9:25 PM 3/13/2003]
