L-46 engine install question
As we (my mechanic and I) prepare for the installation of my new (well, rebuilt) engine, I have a few questions that I hope someone who has already done this can answer.
My 69 L-46 (originally) non A/C coupe has a NOM. I will soon be removing this motor and will replace it with a rebuilt "010" small block. The machinist is done with the block and I plan to pick it up and bring it to the garage this weekend.
Since I plan to rebuild to stock specifications, I have purchased all of the parts necessary to recreate a 69 L-46. Although I will be reusing the original exhaust manifold, valve covers and distributor, everything else on the block will be new. I have purchased new ignition shielding, heat shields, etc (the original shielding was lost when they pulled the engine back in the 70s).
It seems to me that it would be a lot easier to completely assemble the block, including the exhaust manifold, and all shielding and ignition wires prior to dropping it into the car.
Also, since I do not have an original block to compare, I am wondering if anyone can help with instructions/photos of the locations of the various wire brackets, clips and fastners for the ignition wires/shielding. I do have an assembly manual, but find it rather vague as to exact placement of these items.
Thanks.
Mark
Thanks.
Mark
Re: L-46 engine install question (Burgandy 69)
It would be easier on the back to assemble as much as possible before dropping it in. Just remember that the more stuff hanging on the engine is the more stuff that can get in the way as you guide it into place. Depending on how you plan to hook a chain to the engine, sometimes the chain can come into contact with accesories and possibly damage things. Sorry I can help you with pics or locations of wire shields. Maybe theres a vintage vette show near you and you could go have a look see. Find an all original 69 L46 and snap some photos. Good luck
Also this might be of some help to you on the ignition wire shielding. Go to the general topics section and post an inquiry in the factory correct resto forum. Might get more action on that question there.
I would agree with you... Much easier to have the heat shields, lower ignition shielding, and plug wires installed. As was noted in the other section, I'd leave the distributor, carburetor, alternator, and A.I.R. pump off until the engine was reinstalled (although I would probably have the brackets installed)... It is relatively easy to install those items after the engine is back in place and eliminates the possibility of damage.
Unfortunately, there's a lot of "stuff" hanging off of a small block... Take your time and study the manual. With the engine out of the car it should be relatively easy to test fit parts to see how they line up.
Regards,
Re: L-46 engine install question (Rowdy Rat)
Thanks for your thoughts. Since the block is on a cradle, I do have the luxury of test fitting, etc before hand.
Mark
Mark
