Can you fit a C4 glass spring in a C3?
Old 03-12-2003, 01:43 AM
Chris O'
Chris O''s Avatar
Default Can you fit a C4 glass spring in a C3?
The rear spring from an 84 looks very close to fitting. I think the C3 & C4 are 2 1/4 in wide but slightly diff in length.
Anyone done it.
:cheers:
Old 03-12-2003, 01:49 AM
Metal Wulf
Metal Wulf's Avatar
Default Re: Can you fit a C4 glass spring in a C3? (Chris O')
why would you want to ?
Old 03-12-2003, 01:55 AM
Chris O'
Chris O''s Avatar
Default Re: Can you fit a C4 glass spring in a C3? (Metal_Wulf)
Maybe the same reason they changed to a glass spring in the late C3's. Weight saving? Better handling?
I have a '77.
Old 03-12-2003, 02:02 AM
Metal Wulf
Metal Wulf's Avatar
Vette Brakes and a bunch of other vendors sell fiberglass springs for the C3...
Old 03-12-2003, 06:33 PM
Chris O'
Chris O''s Avatar
Thanks MW - at least I got 1 reply!
Vette Brakes is 10 000 miles away and the part I'm looking at is 20 miles away! Exchange rate is ridiculous as well! Sometimes I don't know why I bother asking!
I can't believe no one has ever contemplated it! The C4 spring looks like it would fit, is the same witdh at the mounting point, but a little longer I think.
It's not as if we can just go around the corner for all these parts you know!
Old 03-12-2003, 06:36 PM
88'Cubka
88'Cubka's Avatar
St. Jude Donor '08
The way you mount the springs is differnt. C3 is 3 bots, and the C4 is 4. + the c4 spring is a bit longer.
Old 03-12-2003, 06:39 PM
HDIronman
HDIronman's Avatar
Obtaining parts must be :banghead: over there. If the spring is a good price I would buy it. You can sometimes shorten if necessary. I picked up a spring at a sale for real cheap and I'm going to retro fit it this spring. If the mount is correct it should work. You'll also need gas shocks.
:cool:
Old 03-13-2003, 01:02 AM
Chris O'
Chris O''s Avatar
Default Re: Can you fit a C4 glass spring in a C3? (HDIronman)
:thumbs: Thanks!
Old 03-13-2003, 07:55 AM
mapman
mapman's Avatar
Default Re: Can you fit a C4 glass spring in a C3? (88'Cubka)
The way you mount the springs is differnt. C3 is 3 bots, and the C4 is 4. ......
Your C3 spring should be held on with 4 bolts. 1980-82 (Dana Aluminum) used 3 bolts, so the metal 1980 spring and the stock fiberglass springs in 1981-82 were held with 3 bolts.
Old 03-13-2003, 08:07 AM
Ganey
Ganey's Avatar
Chris
A little longer should work from a length standpoint if the spring rate was correct so it would be nice to know exactly or at least approx. diff. in length & the spring rate.
Old 03-13-2003, 10:14 AM
88'Cubka
88'Cubka's Avatar
St. Jude Donor '08
Default Re: Can you fit a C4 glass spring in a C3? (mapman)
My 80's is held on with 3 bolts, and my brothers 88 is held on with 4.
Old 03-13-2003, 07:06 PM
Chris O'
Chris O''s Avatar
Default Re: Can you fit a C4 glass spring in a C3? (Ganey)
Ganey
I think the diff in length is only about 20mm but the C4 spring was still mounted in a complete cutaway rear end so it had no weight on it. It used 4 mounting bolts as does my '77 but the C4 uses a lot of spacers in the mounting bracket.
As soon as my mate finishes his rear bushings we'll drop it down and do a swap and measure it then. I reckon it'll go close.
:cheers:
To Can you fit a C4 glass spring in a C3?
Quick Reply: Can you fit a C4 glass spring in a C3?
