No oil to the valve train
I started my engine for the first time last night and I'm not getting very much oil to the valve train. The oil presure gage says I have 40lbs. I dont know where to go now. Its a 350 in a 1974 any ideas where to start looking. I think its time to rebuild. Thanks! :smash:
Re: No oil to the valve train (lil ski)
I don't think it's time for a rebuild. Prolly just gonna take a minute for the oil to get back up to the top of the engine since it hasn't been running for a while.
Brett :thumbs:
Brett :thumbs:
If you havent removed the valve covers I suggest you do, disconnect the coil wire and have a friend crank the motor so you can see if any oil get to the top end.
Is this a brand new motor? Solid or hydraulic lifters?did you install oil restrictors for any reason? also the pipe plugs in the front oil boss (or is it rear?)can be installed too deeply cutting off oil flow .since the oil pressure gauge connects at the top of the supply gallery, it really isnt much help .
Re: No oil to the valve train (fauxrs)
Valve covers are off and it is not a new motor and it has hydraulic lifters. The moter is tapping (comming from the front of the motor) I was thinking it has a stuck lifter. I havent run it for more than a minute. I made a priming tool for the oil pump and will try running it tonight. The car sat for a few years before i got it. The guy said he ran it once a year but I dont think he did because the gas was so bad it was even hard to light the burn pile with it. I cleaned the tank, lines and carb.
Don't sweat it could take a minute or so running before you see any oil then it might only trickle out, that"s all mine does, just enough to keep the ball and pushrod end lubricated, comes out faster if you rev it up but I don't recommend doing that with the vavle covers off :D
I have seen oil get awfully gummy after sitting. Saw one car that the oil was dug out with a coat hangar after the car sat for a couple years. Not kidding either, a coat hangar. I hope you changed the oil first. Good luck. Oh, one way to check closer is to use a cutout valve cover. Put a towel over the slot and give it some juice. Not real messy, but your manifolds will probably smoke a little. :flag
Just one clicking is not a problem. Stuck lifters happen all the time in older engines that sit for any length of time. It's due to the lifter bleeding all the way down (think holding a valve open for months), and any varnish/sludge/goo will make it hang up. Running it a while 'till it is warmed up should do it. Try not to buzz it to high 'till it goes away...
If you had a real oiling problem, all of 'em would be clattering.
Hans
[Modified by Wrencher, 2:42 PM 3/11/2003]
Hans
