clutch question
clutch question
just wondering at what point does your clutch engage? refering to how far the pedal is off the floor just when the rear wheels start to spin.
I have mine adjusted that it engages about an inch off the floor but the throwout bearing is still spinning with the pedal fully up - although it's not spinning as fast as pressure plate. So I plan to turn the adjustments nuts a little at a time until the bearing stops competely. And hope I can still shift gears cleanly.
Re: clutch question (70vetteinpieces)
Mine is about 2 inches but the t/o bearing isn't fully released at the top. I need to adjust it.
