centerline autodrags
someone thats using 15x8 1/2 with 3 5/16 inch backspacing autodrags on the front, can you tell me what size tire your using to keep them from rubbing??
Re: centerline autodrags (hotbrakesracing)
I used these rims all around with no rub with the 255's on my '76 here. The backspacing moved the rim outboard 1/2 inch plus the additional 1/2 width over stock.
My fronts with 3.5 inch backspacing with 265-50-15 have absolutely no rubbing. On the back I have 5 inch backspacing with 305-50-15s.
