Will modifying a performer intake work as well as a RPM intake?
I've nearly finished my engine package, and one thing I feel is a limiting factor is the performer intake.
Several people have told me that they can be modified to work like an RPM intake, which works out great since you don't have hood clearance issues.
Basically, the modification consists of cutting part of the plenuim divider out. I think it's 1/2" in on both sides, and 1" down.
Is this modification worthwhile in terms of power increase, considering that I change the stock Q-Jet out? Would it be better to buy a Performer RPM?
What I am looking for in terms of power is enough to run 0-60mph in less than 5 seconds. Currently, I'm at 5.1 seconds. Will a carb change and intake mod help me reach my goal?
Thanks! :cheers: :seeya
Re: Will modifying a performer intake work as well as a RPM intake? (shotgun_000)
Before cutting the divider, you should try an insulating open spacer & an insulating 4 hole or divided spacer. What is gasket/spacer & air filter now?
Do you have 2101, x-over, high flow mufflers?
You want everything dialed in like carb, timing, dist. adv., cam adv., etc.
More rocker ratio like Comp Cams roller tip instead of unneeded rollers & MSD.
Re: Will modifying a performer intake work as well as a RPM intake? (Ganey)
Regarding the roller tips, would it be better to go with the 1.6's, rather than 1.5's, now that I have a better exhaust, and soon to be better intake? I want to make sure I don't kill bottom end power.
[Modified by shotgun_000, 12:16 PM 3/10/2003]
Before you can make the decision to go to 1.6 rockers you need to know what lift your cam is. Low-end torque can drop if there is to much lift. The performer intake can give you more low-end torque than the RPM. The RPM gives you more top end (rpm's above 5500). 1.6 rockers are just another way of getting higher lift. It would be better to get the right cam because the lift and lobe timing would match what you need.
There is a bit more difference in a preformer & a rpm than the divider.I switched to the rpm and it was a big change from idle on up.I also added the 1.6 rollers and they do fine.Did not really see a big gain,but some.
