Horn and buzzer relay
I looked and still cant find the little bugger. I looked in the old posts still no help. I need to find the horn relay on my 74. Chasing the bubba wiring is making me gray fast. Thanks for the help you guys have been great in the past for help!!! :flag
Re: Horn and buzzer relay (lil ski)
I don't know if it's the same, but on my 69, the horn relay is located in the engine compartment on or near the driver's side fender well.
AC
AC
Re: Horn and buzzer relay (A C)
I had hard time finding mine also , because I didn't have a horn relay! , bubba had figured a way to wire around this missing realy. So , just beacuse the car is supposed to have one ........ :crazy:
AC
AC
Look at the harness connection on the firewall, find the 12 gauge red wire and trace it to the relay, or disconnect the horns and have someone press the horn button and listen for the clicking noise it makes, or leave the keys in the ignition with the drivers door open and the buzzer will lead you to it. On most C3's it will be under the drivers side fender.
Re: Horn and buzzer relay (427basketcase)
I'll try that. Back in search of after work hope I find it. Than on to the next problem....... :smash:
