starter options
starter options
Has anyone used the Powermaster starters. I am looking at the MasterTorque model. How about the Protorque starters? I did a search and read mixed opinions about other than OEM starters. When I removed my starter the large bolt on the solenoid pulled out of the housing. I bought a new solenoid, so when removing the old solenoid I found the screws siezed in the aluminum casting :mad I cut the heads off of the screws and drilled for an easy out. One screw stud came out but while working the other the aluminum flange broke :mad :cuss soooo now I have a OEM boat anchor. Maybe I can use it for something usefull like throwing it through the hood of a Honda :D
Re: starter options (jetech)
When I built my motor, I contacted a local starter/alt rebuilder. This is a place that has been in San Diego for a long time ... and I asked for a high torque unit. He suggested a new mini-starter and I have no regrets. It is quite a bit smaller than the OEM style and has gobs of clearance from the header on that side.
I did not even need to use a heat shield on it. So my suggestion is to NOT spend a lot of time online looking at big companies. Talk to the local rebuilders.
Oh, BTW this unit is not reman it is NEW. Does not have a name brand on it though. Cost me $99
If you have the 168 tooth flywheel/flexplate you can't beat the Delco starter found in 95 454 trucks. Permanent magnet, gear reduction. Weighs less than 10 lbs, draws 1/3 the current of the stock starter and cranks like crazy. Local autoparts stores have them for around $200 incl core charge or you can find them on ebay for much less.
