Advice needed on air dam replacement
I need to replace the front air dam (center section) on my 82. My question is what type of material should it be replaced with? I have seen several different materials (plastic, fiberglass, etc) and not sure what is best to replace this with. Anu advice on where to get one of these and type of material would be appreciated ...
St. Jude Donor '09
Re: Advice needed on air dam replacement (jwatty)
If you are referring to the part that has the rubber skirts attached to it.
http://www.ecklers.com/product.asp?d...N0SM2EP3CCDTC8
I think they only come in urethane.
Don't forget to get your discount code before ordering. This was Ecklers, I'm sure that the others have it too (ZIP, MA) shop around for the best price.
Hope this helps :seeya
