Day at the dyno
Old 03-08-2003, 06:13 PM
PrarieShark
PrarieShark's Avatar
Location: The cure for the blues is eight cylinders roaring
Default Day at the dyno
I had a good day and got some good hints on whare I can make easy improvements for $50. :D
Sorry that photos of graphs are so grainy I will try to explain them as best I can.
First run engine cold ambient temp 62deg. also my first time and unsure of myself. The large breakes in the readings could not be helped his machine he explained has a problem with large distributors.
run starts at 2400rpm torque is 250, horsepower110
max TQ251.6
max HP 191 :rolleyes:
run ends at5200RPM
Second run.
Starts at 2200rpm
Max tq. 290.9
Max hp.192.9
finish run at 5600rpm
3rd run
Starts at 4400rpm
max tq. 259.7
max Hp. 220.0
run ends at 5200 rpm Tq. and Hp. just over 200
Tips I was given
1 My air filters are restrictive.
2 Try a smaller secondary jets.I'm running very rich at the top.
3 I was using 93 octane gas I was told thats a common mistake that next time use 83 for a faster burn.
4 The linkage betweem my carbs is too weak and is flexing too much.
Overall I was pleased with how smoothly she ran with no ignition break up, but I was expecting better power nombers.specialy with a Buick GN putting m to shame with 462 RWHP and an ungodly amount of torque 550+
:eek:
[Modified by PrarieShark, 5:30 PM 3/8/2003]
Old 03-08-2003, 06:15 PM
OHSIXX
Support Corvetteforum!
OHSIXX's Avatar
Default Re: Day at the dyno (PrarieShark)
Congrats to you, but for some reason I cannot bring myself to dyno. :rolleyes:
Old 03-08-2003, 06:20 PM
Metal Wulf
Metal Wulf's Avatar
Default Re: Day at the dyno (OHSIXX)
:cheers:
Old 03-08-2003, 06:22 PM
SuperFast80
SuperFast80's Avatar
Second run.
Starts at 2200rpm
Max tq. 290.9
3rd run
Starts at 4400rpm
max Hp. 220.0
Pretty good max numbers there especially for a set up that needs some fine tuning. :cheers:
Using a 20% loss through the TH350 to the rear wheels, you are looking at ~275 flywheel hp and 362 flywheel tq. I'd say the only think holding you back is the TH350.
Old 03-08-2003, 06:33 PM
PrarieShark
Default Re: Day at the dyno (SuperFast80)
Second run.
Starts at 2200rpm
Max tq. 290.9
3rd run
Starts at 4400rpm
max Hp. 220.0
Yes after seeing a C4 vert with same horsepower readings do 140 in 3rd gear I think your right. :D
To Day at the dyno
Quick Reply: Day at the dyno
