painting underside of hood? should i prime first
Old 03-08-2003, 04:26 PM
Chinaski
Chinaski's Avatar
St. Jude Donor '14
Default painting underside of hood? should i prime first
going to paint the underside of my hood today, should i sand and prime first? or just hit it with krylon rust tough semi-flat?
Old 03-08-2003, 11:27 PM
wombvette
wombvette's Avatar
Default Re: painting underside of hood? should i prime first (eleven79)
The factory did not prime them, but you do as you wish. It might help with adhesion.
Old 03-09-2003, 08:31 AM
vettfixr
vettfixr's Avatar
I treated the underside of my hood just like I treated the rest of the body. Prime with a sandable primer. Sand smooth and then topcoat. Mine has held up well even in the high heat environment under the hood. Good luck.
To painting underside of hood? should i prime first
Quick Reply: painting underside of hood? should i prime first
