stock 72 heads
Old 03-07-2003, 07:27 PM
blue72lt4sc
blue72lt4sc's Avatar
Default stock 72 heads
small block heads what were the valve sizes and chamber sizes for 72 small block heads that came on the corvette in 72...also would i be lucky enough to find some one with flow #'s for those heads? :chevy
Old 03-07-2003, 09:12 PM
tnt76vette
tnt76vette's Avatar
Default Re: stock 72 heads (blue72lt4sc)
According to my "Corvette Black Book", 3 different heads were used on 72 350s. Mostly 3973487s were used on both 350 engines (200 & 255HP), but some 3998916s and 3998993s were used also........Thats all the info I can give ya. Hope it helps. :cheers:
Old 03-07-2003, 09:29 PM
BB73Chris
BB73Chris's Avatar
http://www.mortec.com can give you some casting number info sometimes, for the 3973487 heads it says "used on 71-72 LT1 350, 75 cc chamber"... for the 3998916 it has a little more "also used with 72 LT1, big valves, screw in studs, 76cc chambers"... for 3998993 it says "307/350 72-73 75cc chambers" There's some other neat info on that site too. Hope you figure your heads out!
Old 03-08-2003, 10:04 AM
mbeeman350
mbeeman350's Avatar
St. Jude Donor '03-'05-'06-'07-'09
FYI....Ihave a '72 with the L-48 engine, matching #'s, original trans, etc. The heads are the "487" X heads. These are correct for the year but I am not sure for the Vette. I am told they flow good and I know they have 2.02" and 1.6" valves.
To stock 72 heads
Quick Reply: stock 72 heads
