Broken Seat Frame on a '72
Any suggestions on what to do or how to fix the bottom part of the seat frame of a '72. The bottom frame is broken in the back where the seat back
and bottom stops come together. That whole area on the bottom is bent and loose.
Thanks :sad:
Thanks :sad:
Re: Broken Seat Frame on a '72 (Ed T)
Thanks for the response Ed, I have seen that plate that covers the seat bottom on the back edge. Do you know if they work ?
Mark :cheers:
Mark :cheers:
Thanks again Ed, you have convinced me to give the plate a try instead of buying a used frame. Chances are everyone has the same problem. The seats frames are pretty weak anyway.
Mark :D
Mark :D
Re: Broken Seat Frame on a '72 (mbeeman350)
If you have any rust or dampness in that seat area....you tops are leaking...and that is what rusts out seats and seatbelt mechanisms.....
check carefully before you invest...
GENE
GENE
