[EBAY] Big Block AR engine!!
This is the first time I've seen them list a BBC :cool:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2405845652
Re: [EBAY] Big Block AR engine!! (Metal_Wulf)
nice price but not much HP
Check this one out
Gary
http://store.summitracing.com/partdetail.asp?part=27813
Check this one out
Gary
Re: [EBAY] Big Block AR engine!! (TheVetteDude)
Check this one out
Gary
Check this one out
Gary
I'm not really a big fan of crate motors. All you would need to do with that AR motor to get some more horsepower out of it would be switch to a solid flat tappet or a roller cam.
I love this description: "race prepared nodular crank indexed chamfered". Oh, I thought is might have been a stock GM cast iron crank :lolg: (Not that there's anything wrong with a cast crank :))
Location: The reason time exists is so everything doesn't happen at once
Check this one out
Gary
2k for 70hp isn't worth it IMO
Check this one out
Gary
Am I missing something here? Doesn't torque == horsepower at 5250 rpm? Therefore with 495 ft lbs of torque at 5300, wouldn't the max horsepower be somewhere around 490+ at 5300 rpm? :confused:
From the ad "480 hp @ 5950 RPM 495 ft. lbs torque 5300 RPM "
Re: [EBAY] Big Block AR engine!! (Flareside)
Joe:
Actually for that motor a cast GM crank would suffice. I'm actually running a stock LS4 crankshaft in my motor....and it's putting out more power than the AR one.
[Modified by bence13_33, 4:11 PM 3/7/2003]
