Poly or Rubber T-arm and Strut Bushings
Re: Poly or Rubber T-arm and Strut Bushings (Koz)
I put rubber back in mine since Bairs did my arms However I here if your doing it yourself that Poly is much easier to install.
Premium Supporting Vendor
The upside to poly is that it will last a heck of alot longer than rubber. People who usually purchase poly from us are the guys who like to get on the car a lot or race. 80% of our rebuilds are rubber. Either up front or in the rear. -Dan
Re: Poly or Rubber T-arm and Strut Bushings (Van Steel)
I pulled my trailing arms thinking one of the bushings had failed. I assume they were the original factory rubber bushings, and they were fine. I installed poly - don't tell my NCRS friends, I'm gonna judge soon.
I've heard that poly bushes squeek a lot - could this be due to a lack of lubricant? I'm thinking of replacing mine too.
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Re: Poly or Rubber T-arm and Strut Bushings (Superv)
I did poly because I don't ever want to have to do this ever again. My mom was the original owner of my 73, it will remain in my family forever... I don't want to have to worry about that job ever again. Poly last much longer. :yesnod:
Good luck. :cheers:
