Engine builder pushing SBC over BBC???
I was locked and loaded for 540ci BBC from AR. But they've been persistently pushing me towards SBC for the weight and cost savings.
My 73 is originally BB car; what's involved with putting a SBC in a BB car?
I already have the dewitt Rad/dual electric fan combo... new side pipes and headers were already on the to-do list. What else is there? :confused:
Re: Engine builder pushing SBC over BBC??? (ricketyray)
I am not a super engine guru....Butt (big subject) this question has been asked many times. Here is the general consensus:
1: BB are about 200 lbs heaver than SB
2: It will cost less to make a 454 BB than a SB overbored to 454 cu.in.
3: there is no replacement for displacement
IMO a vette with a BB holds more value, than a SB.
good luck with your choice
cheers
chad
cheers
chad
Accessory brackets. Is your front end gonna be jacked up after losing bout 200 lbs? Would prolly be easier to just get another BB. I would...but then i'm a little prejudiced. :lol: :lol:
Brett :thumbs:
Brett :thumbs:
Re: Engine builder pushing SBC over BBC??? (71'AirStrike)
...1: BB are about 200 lbs heaver than SB...
Chack out the new 454ci small block from the latest Jeg's catalog, gives you BB displacement with small block weight. And it's got the power too. 600hp with 10:8CR :cool:
Re: Engine builder pushing SBC over BBC??? (Brettmc)
Brett :thumbs:
Brett :thumbs:
Re: Engine builder pushing SBC over BBC??? (groovyjay)
That's a lot of ci's for a SB. Wonder what bore and crank combo they used to get that.... think it will hold up? wonder how it does on pump gas?
It all depends on what your real intentions are to do with it. Drive on Weekends, drag race whenever, burn the hell out the rears occasionally,
Live life to the fullest. THERE ONLY ONE ANSWER!!!! BBC!! The 540 is the way I'm going, and there's no way in :reddevil a SBC will ever grace the framerails again. I can't believe there telling you that unless you plan on road racing or doing alot of autocrossing. You already have the brackets and pulleys and all that other BS you need when converting from small to big so stay with Big Cu In.. I see this topic often, and for me I view our C3's as heavy cars. Mine weighed 3475 with my steel head 427, but it felt quick like a small block. It also ran 12.17 with mild mods, hydraulic cam ect. You could build a low compression 540 that would run faster than that with a/c ect.
AR? I thought those guys were small block dudes anyway. Call Sonny Leonard or someone who know BBC's and get there opinion. The only small block cars I see that will run well with some street manners are the Cartek C5's and some forum members who have truly figued out big cu in small blocks. Who wants to shift at 8000 to make power and expect to have an engine that still runs in 5years. I'm sure Ill get some flames from the small block dudes. But hey thats why it's forum right?
Good luck, just my.02 worth.
:flag
:flag
You have a '73 big block car that's all set for the 540 you've been planning, and now you want to ditch that idea and install a low-budget small block from AR? No way, forget it, can't happen. Don't be silly... :D I've owned big and small block cars, and I like the bigger small blocks, but I'd never remove a big block for a small block. Never! :cuss
Re: Engine builder pushing SBC over BBC??? (Corey 68)
It's harder to make the same HP with a small block & may not be as reliable (more stress & limits being pushed with the sbc). There are some awesome smallblocks out there today, but if you already have/ had a BBC in your car, then I would stick with the bib block. Cubic inches= torque= seat of the pants pulling :D . Zora's favorite Corvette was his 1974 454, he sad it was the best, most comfortable cruising Corvette he ever owned ;) .
Check out the new 454ci small block from the latest Jeg's catalog, gives you BB displacement with small block weight. And it's got the power too. 600hp with 10:8CR :cool: :cool: :thumbs:
He who knows not and knows not that he knows not...is a fool...Shun Him.
He who knows not and knows that he knows not is simple...Teach Him.
He who knows and knows not that he knows is asleep....Waken Him.
He who knows and knows that he knows is wise....Follow Him.
:seeya Cappy
Re: Engine builder pushing SBC over BBC??? (8T1-7T9 BIONIC VETTE)
opinions are like (!) everybody has one, I have had both and prefer torque and reliability of BBC.....cubic inches rule, by the way I have small and big block and will build big block to replace the small block hopefully this year. :D will store small block :cheers:
How much cylinder wall is there with 4.25 bores on a sbc? I have a 400 and it's close already with just 4.155 (.30 over). By the way, if you go with the smallblock every time you open the hood you'll have to tell everybody how cool it is and how many cubes and how much power it makes and stuff but if you go with the big block all you have to do is open the hood and they go :eek: ...
I kinda like the 'cool factor' (or i mean... i will like the cool factor)
Re: Engine builder pushing SBC over BBC??? (MassVette)
The SBC has a lot of appeal... I like the weight savings, although the cost get's as high as a BB when you go for big hp...
But, that said, I think I'll have to stay on task with the 540ci BBC...
I think I've already got over 100lb's out the front end with changes mentioned above, and I have a few more ideas I'm rolling around too...
In terms of cost; the plan of using a zz502 block w/ a 4.25 crank, and quality heads and internals isn't breaking the budjet yet...
Most importantly; I'm afraid if I tried to put a SBC in my BB 73 the BB folks from the forum would find out where I live and start planning an intervention. :lol: :lol: :cheers:
Take a good look at the Gen VI 502 block issue before you make that decision. I though long and hard about that option, but the GM based 540 would have cost me more in the end that the Merlin II block that I wound up with (and the Merlin is much stronger). The Merlin (or Dart Big-M) is a Mark IV design, so everything is cheaper. With the 502 block, you need a Gen VI specific valvetrain due to the extra tall lifter bores, timing set and cover, electric fuel pump, Gen VI oil pan, etc. It adds up fast. The 502s are great crate engines, but for a ground-up build there are better choices, IMO (unless you can get the stuff cheap!)
:party: :party: :party:
:cheers:
Re: Engine builder pushing SBC over BBC??? (Flareside)
Good look-out! :thumbs: I'm going to chase down that option too. :)
Any word on when we'll be seeing the zz572 on sale and the cost?
