Need to replace rear spring--fiberglass?
Old 03-06-2003, 08:50 AM
kenr57
kenr57's Avatar
Default Need to replace rear spring--fiberglass?
I need to replace the rear spring on my 74 L82 convertible. Need help deciding between 9 leaf steel spring and composite spring advertised in Hemmings, Mid-America, etc.
Any info would be helpful. Thanks,
Ken
Old 03-06-2003, 08:54 AM
Ganey
Ganey's Avatar
Default Re: Need to replace rear spring--fiberglass? (kenr57)
Go w/ VB composite for less wt.!
:cool:
Old 03-06-2003, 09:00 AM
mrvette
mrvette's Avatar
Default Re: Need to replace rear spring--fiberglass? (Ganey)
Ganey's right, not only that, but it's a bit shorter than the TRW spring, so I hear, and will not hit wider wheels/tires....
GENE
Old 03-06-2003, 09:05 AM
Corey_68
Corey_68's Avatar
Default Re: Need to replace rear spring--fiberglass? (mrvette)
Just by changing to the fiberglass you'll drop 50lbs, I really like mine.
:cheers:
Old 03-06-2003, 09:11 AM
flynhi
flynhi's Avatar
With either VB or TRW, be sure to replace shocks with those designed for fiberglass - KYB GR2s or Bilstein Sports.
Old 03-06-2003, 01:07 PM
kenr57
kenr57's Avatar
Ganey:
Thanks for the reply. I have not seen any info on VB composites, only the TRW brand carried by Mid-America and Eckler's. I'll pay more attention to the brand name when doing research. Thanks again.
Ken
Old 03-06-2003, 02:43 PM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
I think you'll like the fiberglass better. Especially with the KYB's.
Old 03-06-2003, 02:51 PM
theandies
theandies's Avatar
Default Re: Need to replace rear spring--fiberglass? (Van Steel)
I think when I replace my spring I am going back with a steel one. I have yet to see a post "My steel spring just broke". I'm sure they have in the past but I am not going to take a chance. I am the kind of person that would run out and look at a composite spring every time I came on here and read a post "My composite spring just broke".
JMHO
John
Old 03-06-2003, 03:50 PM
BB2B
BB2B's Avatar
Default Re: Need to replace rear spring--fiberglass? (theandies)
I used the VB 330#/in model. It rides very nice. Good gas shocks are a "must".
Old 03-06-2003, 04:06 PM
Van Steel
Van Steel's Avatar
We actually had a guy come to our shop with his vette(flatbeded) because his rear steel spring colapsed on him when he was taking off. His spring looked like an ancordian.
Old 03-06-2003, 09:22 PM
JRD77VET
JRD77VET's Avatar
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
We actually had a guy come to our shop with his vette(flatbeded) because his rear steel spring collapsed on him when he was taking off. His spring looked like an accordion.
Olivier, Grand Sport C3 had his steel spring break while he was driving. Luckily he was going very slow or the results could have been disastrous.
:seeya JRD77VET
Old 03-06-2003, 09:41 PM
theandies
theandies's Avatar
My guess is that these were the original springs..............I am sticking with steel when I change mine.
John
[Modified by theandies, 8:42 PM 3/6/2003]
Old 03-06-2003, 09:53 PM
Alwyn678
Alwyn678's Avatar
John
:iagree:
Old 03-06-2003, 09:59 PM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Need to replace rear spring--fiberglass? (BB2B)
Every Corvette since 1982 came with a composite rear spring, and the C4's even had them in the front.
If composites were such the nightmare that everyone here paints them to be, then why did GM put them in so many cars?
The composites are AWESOME !!
And steel springs do break, and probably about as often as the composites do.
Old 03-07-2003, 03:35 PM
vettfixr
vettfixr's Avatar
Default Re: Need to replace rear spring--fiberglass? (BSeery)
My steel spring broke and was the reason I went to a fiberglass spring. I was driving home and went over a small bump (actually a depression in the road) and felt the rear end crash down. Luckily no damage was done to the car. I put a TRW 340 lb spring on my 74 back when VB&P only sold the TRW springs. I can't even remember how long ago that was, probably over 10 years ago. I've never regretted going with the fiberglass spring. If I had to do it over again I might have gone with a 360 pound spring because a fiberglass spring tends to ride smoother than a comparable steel one.
Old 03-07-2003, 05:28 PM
79VetteMike
79VetteMike's Avatar
What is the difference between the TRW spring sold by Muskegon Brake and the composite spring sold by VBP?
Is there a weight difference? Personally, I like the cheaper price of the TRW spring, but am I missing something on why a VBP spring is better? Thanks...
Old 03-07-2003, 06:45 PM
79VetteMike
Default Re: Need to replace rear spring--fiberglass? (79VetteMike)
TTT
Old 03-07-2003, 07:15 PM
Crash Dummy
Crash Dummy's Avatar
St. Jude Contributor
kenr57...
I went to the Houston Corvette Show recently and went through VBP's section and their rear composite monospring weighs almost nothing. I picked up the 360lb spring kit(all hardware) with poly mounts for $339.00(they paid shipping). Definitely alot more than their steel springs($175.00... includes hardware). I've got a mechanic doing all the suspension work, but when I get it back I'll take some pics of what it looks like with the new KGB's that are also going on.
To Need to replace rear spring--fiberglass?
Quick Reply: Need to replace rear spring--fiberglass?
