Anyone seen these Carbon Fiber Half shafts?
Was wondering if anyone saw these are ever used them. I'm sure they are $$$
http://www.pstds.com/index.cfm
scroll down to the bottom of the first page.
Tim
Tim
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Anyone seen these Carbon Fiber Half shafts? (WillRace4Food)
Considering your posting in C3 about parts for C4s only, I don't know what response you will get in here.
CFOT Attention Whore
i'm sure if you threw enough money at them they would make some super special c3 shafts. *drool*
Re: Anyone seen these Carbon Fiber Half shafts? (clutchdust)
I knew they show only c4-c5 setups but they have a custom order sheet. They will make any lenth you want. I just got a custom length DS for my Formula and it was no extra charge. Looks like between 500-600 for a set of carbon fiber half shafts. Thats cheaper than one for my formula. Just trying to share some info guys.
[Modified by WillRace4Food, 6:19 AM 3/6/2003]
Re: Anyone seen these Carbon Fiber Half shafts? (Guru_4_hire)
O've seen them before, only on C4's though, For C4 there are 1/2 shafts and a driveshaft available. I saw the price too :crazy:
Re: Anyone seen these Carbon Fiber Half shafts? (Twin_Turbo)
Now these are amazing .... :eek:
Corvette Carbon Fiber Half Shafts
We now have Carbon Fiber Driveshafts specially made to fit your Corvette! Order Now!
[Modified by QuickVet, 8:35 AM 3/6/2003]
what about the driveshaft?
Carbon Fiber Half shafts and Driveshafts are way :cool: :cool: :cool:
Light weight and great strenght!!! :yesnod: :yesnod:
:cheers:
Olivier
:cheers:
Olivier
CI 7-8 Veteran
Re: Anyone seen these Carbon Fiber Half shafts? (GrandSportC3)
Wouldn't this be one of those cases that reduced weight helps more than a 1/1 ratio bordering on exponential? Cause we are reducing rotating mass. Or would this somehow hurt because of lost momentum....in other words, as soon as you let off there is more loss rotationally and would therefore need more power to get back to where you were.
I'm assuming it would be benificial but also may just be different....like a lightweight flywheel. You don't always want a lightweight flywheel in all circumstances, do you?
Re: Anyone seen these Carbon Fiber Half shafts? (tshort)
Re: Anyone seen these Carbon Fiber Half shafts? (ylose)
No..this wouldn’t' be the case. I believe your talking about what is considered as "stored energy". The only time any Stored energy would have any positive effect is on a hard drag strip launch. This is why an alum. flywheel isn't really recommended on a manual car at the drag strip but highly recommended for road race applications. The stored energy of the flywheel while the rpms are up helps get the car out of the hole without bogging. Since the Driveshafts aren't rotating while the car is stationary there isn't stored energy. Any time you can lighten up rotating weight its a good thing for over all performance. There is less mass(weight) to rotate and accelerate thus you have less drive train loss. Lightening the driveshaft is Kinda like going to lighter brake rotors and would have the same kind of affect. I bet they would also custom make some alum. half shafts and driveshaft too for lighter weight and better price. With billet yokes they are pretty strong.
Very :cool: . Now when I tear a half shaft apart I know where to go :lol: :cry . Taking the weight off the rear is a nice change from all the heavy steel back there :yesnod: .
Re: Anyone seen these Carbon Fiber Half shafts? (SmokedTires)
what kind of hp/tq can they take ??
Tim
Premium Supporting Vendor
The carbon fiber half shafts are kind of expensive but worth it if you race. They also come with Billet Aluminum ends where the U-Joints go. -Dan
I feel it's got to be an advantage .. given a performance mod. what is the life duration etc .. On the site I see drive shafts made this way too? Are they are cool and good to go, how straight/matched can they be for street too? :cool:
[Modified by Purplerainz, 2:52 PM 3/6/2003]
