mystery cooling part
(1977 L-48) I pulled a part out of my engine and I'm not sure what it is or what it does, and I couldn't find any documentation on it. It had coolant lines on either side, one to the heater, the other to the intake manifold. It also had a thin plastic tube running from it to the rear wall of the engine compartment. Just wondering what it is.
For a visual (bottom right picture on the page):
http://booferpics.012webpages.com/Booferpics.htm
Re: mystery cooling part (Boofers)
no ,it helps keep the hot water from circulating through the heater core.helps with less heat in the drivers compartment.
