Ground to the radiator in my 79
Hello,
I have a 79 L82. My temperature guage pins to the right (and isn't functional). This happened when I got my radiator replaced. I heard that there is a ground to the radiator. Does anyone know where this ground is? Thanks,
Nathaniel
[Modified by both79, 10:14 AM 3/4/2003]
Nathaniel
Re: Ground to the radiator in my 79 (Neo Fender)
It is plugged in, I've even replaced it. The reason I ask about the ground to the radiator is 1) it stopped working after I got the radiator replaced and 2) In my research into this problem I heard that there is a ground to the radiator that might effect it. Thank-you for any and all input. The car would be near perfect if I can get this going.
Nathaniel
Nathaniel
Re: Ground to the radiator in my 79 (both79)
Hmm. The block should act as the ground for the sender. I'm not aware of a ground on the radiator - doesn't mean there ain't one though.
You may want to check for continuity between the sender wire up to the gauge. Also, check for a short to ground while your there. In my experience, temp senders vary greatly. The first replacement I bought did not work. It would peg to the right after only about two minutes of driving.
Good Luck
Good Luck
Cruise-In VIII Veteran
Good Luck
Good Luck
Did you use teflon tape on the replacement sender. I'm not sure about temp, but I know that oil (electric) will peg when it loses ground. If the sender is in good shape and tape is not letting it ground, it pegs. just my .02
Re: Ground to the radiator in my 79 (Avette4me)
Thanks for the input all. I did not use any tape or sealent when I put the new sensor in. I might have to put another one in, at least they aren't that expensive. I have checked for contiunality and didn't find a problem there either.
Any other input would be great. Otherwise the great search will contiune.
Nathaniel
Nathaniel
To answer your original question. There is a ground wire on the drivers side of the radiator support on my '69. It goes up into the wiring harness near the horn relay. I noticed it when I removed the core support but didn't bother to chase the wire to find out exactly where it goes.
The wire mounted on a small hex head bolt about 1/2 way down the drivers side edge, on the front side of the support itself. Oddly enough, the new support doesn't have a hole for that bolt so I'll have to drill one when I reinstall the new support.
Shannon
Shannon
No problem. BTW the black ground wire there is for stock lights. The blue is for a Hella driving light circuit separate from the stock electrical system.
Re: Ground to the radiator in my 79 (78Vette-SA)
My temp guage did that when i put in my cd player. It turned out to be a wire at the back of the guage consol that is really sentitive because it's so old.. I just moved it around a abit then put the guage cluster back in now it works fine.
