redoing driveshafts, rear end-any photos out there?
going to refinish drive shafts and rear end, wrong grey was used,,any photo's of painted or por-15 'd- out there?-how about frt.end parts?---carl
[Modified by carl a, 3:42 PM 3/4/2003]
Re: redoing driveshafts, rear end-any photos out there? (carl a)
If you're trying to go original, the driveshaft and rear end are not supposed to be painted at all- natural cast iron and steel.
Re: redoing driveshafts, rear end-any photos out there? (Mike Ward)
what i was trying to do was avoid rust-so when i did the body off i wanted show quality. which i acheived by gettig 997 points outta 1000- the problem is i wanted to use por-15 on all metal parts- the frame was por'ed then i sent it out to z bart and had it sprayed inside the rails( couldnt get my hands on a z bart tool to spray por-15 inside the frame) the shop that did the drive shafts used ''manifold grey- which is great for exhaust manifolds-but doesnt''cure ''till 500 degrees f.-por -15 makes a metal coating that looks like bare metal--but wont rust-- they used the wrong stuff------ carl-----------
You can see mine at my website below :) . :cheers:
Re: redoing driveshafts, rear end-any photos out there? (SmokedTires)
looks nice-maby ill go with black por-15-did you coat your brake backing plates? i know there anodized but they still get bad looking if not coated-im always cleaning--this is why i wanted to use por- drive it-- squirt her down --go to show!!!
[Modified by carl a, 11:31 PM 3/4/2003]
Here's mine after I put it back together. I kind of like the silver.
[Modified by 79MakoL82, 6:48 PM 3/4/2003]
Re: redoing driveshafts, rear end-any photos out there? (79MakoL82)
Here you go, don't mind the front sway bar for it is upside down in this pic
Neil in Tenn
[Modified by Nomad78SA, 8:42 PM 3/4/2003]
Neil in Tenn
Re: redoing driveshafts, rear end-any photos out there? (Nomad78SA)
I used Eastwood's Detail Gray on mine. I sandblasted the driveshaft and half shafts. They actually fit in my benchtop cabinet. I used a wire wheel on a drill for the diff.
looks great!--thats how mine looked 2000 miles ago-backing plates get bad lookin real fast--i gotta spray them with a product from por called glisen p.c.-the fins on the rotors- are gettin surface rust--im going with black fins( por-15) and red calipers- is that por on your frame? looks beautiful--carl
