Re: 1979 #3932461 Exhaust Manifolds. Same on Both Sides? (paul79)
paul, i can confirm that my passenger side manifold has the same # as you posted, the driver's side appears to be the same but the heat riser pipe "tin" enclosure is covering up the #'s.
