PLEASE HELP
Cruising
PLEASE HELP
I have a holley street dominator intake manifold with a standard qjet carburetor, i made a recent engine rebuild and i'm having problems, the car idlle ok but runs lean. doesnt drive, just iddle. could it be a fuel pump prioblem?, or as i have more comresion on cilynders , could it be a bad combination between intake manifold an carburetor?
please help
please help
Re: PLEASE HELP (spanishvette)
Carb should work with that intake.Think I would check for vacuum leaks,timing,valve lash and the sort.Could be a pump problem and that is easy to check.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
I agree it sounds like a vacume leak and or a bad fuel pump.
