Filling in the holes
I recently bought a 77 vette and the owner before put on a front spoiler and a california turbo wing and they are bolt on assemblies. I am not particularly fond of the spoiler and wing and want to take them off. But when I do there will be holes in the fiberglass. Does someone make a patching substance of any kind to fill in the holes? Thanks :chevy
[Modified by RCDriveryo, 4:18 AM 3/3/2003]
Re: Filling in the holes (RCDriveryo)
I've used the light weight grade of fiberglass mat that you can easily pull apart (like a wad of hair) and was happy with the results. You just pull some apart and set it where you can easily get to it, mix up some resin, brush the area with resin. Stick the fiberglass to the area and with your brush dap it with more resin till it's soaked and invisible, add more fiberglass on top of it if you need to and wet it down. Once you sand you might need to do so again. when it hardens, it will sand out nice and smooth. Good luck! :cheers:
You could use all kinds of stuff (cualk, gum, 2 part epoxy, etc.) as a "hole filler" if you really want to. But if you want to do it right then glass is the way to go. To answer your question though, I don't think I've ever seen a product named "hole filler". :cheers:
Re: Filling in the holes (litevette)
:iagree:
Maybe in the future the wizards at 3M will invent a hole filler, but for now it's fixing fibreglass with fibreglass. Other products may look good at the start, but eventually stress and temperatures will scar it for life, and you'll have to do it over again.
The only way to go is to use fiberglass. I just did this repair for rearview mirror removal. Make sure you cone out the holes to give the fiberglass more surface area to bond to . Cut some fiberglass to fit in the bottom of thre hole then mix and set the fiberglass mat. Don't try to completely fill the hole in one try. The best way is to do it in two to three steps. Doing the repair this way wil keep the holes from reappearing after you paint your car. Hope this helps.
