CAN YOU RUN A TEST FOR ME? ON DYNO2000
CAN ANY ONE RUN A TEST WITH THIS SET UP PLEASE. I HAVE AN L-82 AUTO AND 355 GEARS WITH STOCK EVERYTHING EXCEPT, I INSTALLED COMP CAM 268XE, 1.6 ROLLER TIPS ROCKERS, TRUE DUAL EXHUST 2.5" AND A MALLORY HYFIRE CD IGNITION. IF POSSIPLE CAN YOU TRY WITH EDLERBROCKS RPM ALUM. HEADS WITH 64 & 76 CCS OR WITH 487X IRON HEADS? MUCH EPRECIATED I WILL ADD ALSO A SNIPPER 100 SHOT NITROUS
MAURICE
MAURICE
Re: CAN YOU RUN A TEST FOR ME? ON DYNO2000 (silver79)
Are you sure that is the cam that you have? You should have coil bind on the stock valve springs with this much lift.
At any rate, you should have about 276 HP at 5000RPM and 343 TQ at 3500 RPM currently and a change to 64 c.c. Edelbrock heads will get you to around 319 HP and 361 TQ at the same RPM's.
The peak hordepower on both combinations that I tried for you were at 5000 RPM. Peak torque was at 3500 RPM.
My engine has a bit more HP and TQ, but not nearly enough. I'm currently assembling a 406. :D :smash:
