wiring diagram for a 73
Old 03-02-2003, 07:43 PM
brookman
brookman's Avatar
Default wiring diagram for a 73
Does any one have a wiring diagram for a 73? The current owner said that 18 years ago he parked it because after smoke came out from the drivers kick panel it wouldn't turn on any more.
Old 03-02-2003, 08:07 PM
FERL 73
FERL 73's Avatar
Default Re: wiring diagram for a 73 (brookman)
Try the 73spot. A fellow Forum member. He has a great deal of good info!
http://www.corvetteforum.net/c3/vette73/wiring.htm
Old 03-02-2003, 09:13 PM
trw
trw's Avatar
There really isn't anything in the kick panel, but the fuse box is right there.
What type of diagram are you looking for. I bought a large one from Lectric Limited (about 16' x 22") they are less than $20.
Terry
Old 03-02-2003, 09:37 PM
brookman
brookman's Avatar
Default Re: wiring diagram for a 73 (FERL 73)
Thanks a bunch.
Old 03-03-2003, 07:05 PM
RMS73
RMS73's Avatar
You have an e-mail. :D
Roger
Old 03-04-2003, 07:32 PM
carl a
carl a's Avatar
Default Re: wiring diagram for a 73 (RMS73)
i e mailed you the 2 i have-- hope it came out------if not need a fax #-carl a
Old 03-05-2003, 08:01 AM
GaryS
GaryS's Avatar
Since the fuse block is only a few inches away from that area, I would suggest that the problem lies there. However, if the posters above aren't able to help you, the 1973 AIM has a nice wiring diagram and you can also order one from Lectric Limited.
Gary
To wiring diagram for a 73
Quick Reply: wiring diagram for a 73
