LED dash bulbs
Old 03-02-2003, 06:47 PM
Superv
Superv's Avatar
Default LED dash bulbs
It's time to tinker again!
My dash lights have stopped working, can't see a blown fuse - any ideas.
Also I'm thinking of replacing the dash bulbs with coloured LED replacements.
Maybe blue. Has anyone used LED's in there car - how bright are they?
Have a look at this site
http://www.superbrightleds.com/1157.htm
Old 03-02-2003, 07:25 PM
Armstrong
Armstrong's Avatar
Default Re: LED dash bulbs (Superv)
I haven't used em but if you get em let us know how it turns out.
Sounds like it could be a real PIA with the polarity issue
Old 03-02-2003, 08:35 PM
Paul L
Paul L's Avatar
Default Re: LED dash bulbs (Armstrong)
Anyone used the 1157s in tail/brake?
Old 03-02-2003, 08:53 PM
Metal Wulf
Metal Wulf's Avatar
Default Re: LED dash bulbs (paul79)
sounds like you need a new headlight switch...
Old 03-02-2003, 09:55 PM
s79vette
s79vette's Avatar
I bought the 1157 leds for taillites and wasn't impressed, took them out
got brighter filiment bulbs but can't recall the number, 1167 maybe? Didn't
save card and would have to take one out to verify. They are brighter. I liked
the image of the led lite snapping on and off as in Deville but they were
dimmer than stock. Steve
Old 03-02-2003, 10:14 PM
Paul L
Paul L's Avatar
Default Re: LED dash bulbs (s79vette)
Thanks Steve. I didn't think they were worth the money! A lot of hype associated with these LED lighting systems. It all eventually falls back on a basic 1157. I have not heard of a 1167. Will check it out.
Old 03-03-2003, 03:31 AM
Superv
Superv's Avatar
Default Re: LED dash bulbs (Metal_Wulf)
Metal_Wulf - That's what I feared. Looks like an butt pain to remove,I need to do the wiper switch as well.
Does anyone know the code for the dash bulbs and how many of them there is ?
Old 03-03-2003, 07:21 AM
Monkeywrench
Monkeywrench's Avatar
For '71 it was (may be different for 79?):
#1895 there are 6 in each guage pod so a total or 12 in the driver's side dash. There are some lower courtsey lights as well.
[Modified by Monkeywrench, 7:28 AM 3/3/2003]
Old 03-03-2003, 08:45 AM
pws69
pws69's Avatar
That's interesting.... The 1157 replacement LED's that I have are VERY bright - much brighter than a filament type (1157, etc.). I also like the instantaneous on/off.
Paul
Old 03-03-2003, 02:41 PM
NHvette
NHvette's Avatar
I think the 79 has the printed circuit board dash - and takes the push-in type (like 164). These are readiuly available in LEDs - but the early style, I have not seen.
:seeya
Old 03-03-2003, 05:29 PM
Paul L
Paul L's Avatar
Default Re: LED dash bulbs (pws69)
What brand did you purchase?
Old 03-03-2003, 05:37 PM
Metal Wulf
Metal Wulf's Avatar
It's easier than you think... took me like 10-15 mins to change out mine :thumbs:
Old 03-03-2003, 06:09 PM
Cookwithvette
Cookwithvette's Avatar
Just wanted to say, I've used blue LEDs in a computer. They are EXTREMELY bright. Not sure about the bulbs they sell but bare bulbs at 12 volts are blinding.
Old 03-03-2003, 06:15 PM
battsup
battsup's Avatar
Default Re: LED dash bulbs (Cookwithvette)
i agree, if your going to use blue LEDs then make sure they are positioned so they are not directly in front of the light slots.
Old 03-03-2003, 09:15 PM
Superv
Superv's Avatar
Default Re: LED dash bulbs (battsup)
On the blues, are they a deep blue or do they come out light?
I want them bright because they sit behind they gauges and I want the cluster to light up In a nice deep blue. Also I don't know if the dimmer on the light switch will go down low enough to dim the LEDs if needed.
I'm definately getting them from the states though - they want £14.00 per pair over here! SuperBriteLeds are only $2.49 each for the same thing.
What about Ultra violet LEDs that would make the digits and needles glow in the dark.. would look quite trick.
Old 03-04-2003, 02:00 AM
442olds
442olds's Avatar
The next brighter standard buld is the 2057 for those that still want to use the a standard buld.
I am working on making installing the new 10 led trailer lights behind the stock tailight lens. And if that still isn't bright enough I will swap in the 40 led trailer light. But they are pretty blinding now without the vette lenses in place.
Old 03-04-2003, 09:16 AM
pws69
pws69's Avatar
I got them from Stylin' Concepts.
To LED dash bulbs
Old 03-04-2003, 07:59 PM
s79vette
s79vette's Avatar
I was in Auto Zone one day and saw a 1157 led on a card and bought it. It was
5 or 6 bucks. I wanted to try one before shelling out 20. I also found them on
the internet for 14 dollars a piece about the same time. Maybe I got what I paid
for, a dim led. Steve
Old 03-05-2003, 02:19 PM
CMYC4GO
CMYC4GO's Avatar
I think the bulbs that you are talking about are 2157's . Also, in JC Whitney, you can get 1157H (Halogens) bulbs for about $12 a set, and they ARE A LOT brighter than stock bulbs. :thumbs:
Old 03-05-2003, 02:34 PM
CMYC4GO
CMYC4GO's Avatar
If you really want to turn your C3 into a head turner, you can get LED tail lights, and do it VERY reasonably. All it takes is a trip down to your nearest truckstop or truck parts store. You can get 4" round LED tail lights for a truck, and pick up the rubber grommets. After you remove your tailight assembly/backup light assembly you can insert those taillights into those rubber grommets, and insert into your tailight holes, and they fit PERFECTLY. Youll lose your backup lights, but your Vette will look neater n hell :thumbs: You'll also have get the pigtails, but those are cheap. If you look for sales, you can do the whole job for under $100. :auto:
Quick Reply: LED dash bulbs
