Rear Spring and Shocks Replaced, anything else?
I'm having the rear leaf spring and shocks replaced, is there anything else
I should consider having done at the same time to save money?
Thanks
Thanks
Re: Rear Spring and Shocks Replaced, anything else? (Scudd)
May as well have new bushings put in the strut rods. Also a good time to check the differential yokes.
Make sure you do a composite monospring instead of metal leafs, and get compatible shocks. The guys at Vette Brakes and Products can probably help. You may want to go for matching front shocks as well. Small warning: Don't be surprised if your (car's) rear end is a bit jacked up, and prepare for this.
Thanks
Thanks
There are several "while you're at its." It's a long list. Shocks and spring are not big tear-downs, so I don't think you'd be kicking yourself later for not doing more.
Make sure you check the U-joints for safety sake. How many miles on your car?
Install longer grade 8 spring bolts to adjust ride height. Replace all bushings with poly. If your budget permits, install Smart Struts bracket and struts. Change diff fluid.
St. Jude Contributor
Re: Rear Spring and Shocks Replaced, anything else? (Runner81)
