Gas Prices and Octane
Has anybody with stock 350s :lol: beside me considered running a lower octane fuel because of the high cost of gas. I haven't done it yet but seriously considering doing so. Think there will be any problems. What does the 350 require? It's not listed in my owners manual. :nonod: :flag
Re: Gas Prices and Octane (N5OMU)
Look under the hood right above the brake master cylinder, there should be your information on what oct to run. If not, what year and eng option to your have? You can always exp with it by dropping the oct. Just let the tank run to 'E' then fill up half way in case your eng doesn't like the new gas you put more higher oct fuel in. One the new gas has had time to get into the carb give it some full throttle runs, if it pings you can either change back to higher oct or try retarding your timing. You only have to run oct high enough to keep your eng from detonating with your set-up, anyhigher yeailds no performance increase unless you to some eng adj.
I have a stock L48 in my '77.
I've run 87 octane the whole time I've had it.
Very rarely, I'll hear light pinging.
I did try the 93 octane on a couple of trips and noticed no performance or MPG improvement.
I've been averaging about 15.5 MPG.
I agree with Fevre and Jerry. If it runs good on lower octane, there's no benefit (except to the oil co :)). There are situations where a low compression engine might need higher octane but if yours doesn't, save your money.
Cruise-In VI Veteran
Cruise-In VII Veteran
I agree with the other guys, there is no reason to run hi octane if you have a stock L-48 or any fairly low compression engine. Now if you have a high performance, hi-compression engine then you probably need the highest octane fuel you can get.
