Edelbrock Thunder Series AVS??
so I finally got to take my 1970 BB 454 in to get a new carb (don't have the original Q-jet, or anything worth rebuilding) a new intake manifold, MSD blah blah. Anyway, my point, when I told him to go with an E/B 750 Q-jet, and he had other ideas. He said I would be much better off by going with an E/B Thunder Series AVS with Electric choke, and that's what they normally go with on the C-3's he's worked on that want new carbs. I trust the guy, and after hearing more about his thoughts on the E/B Q-jet, I decided to go with his advice and see what happens. He has gaurantees on everything he does, so if I don't like it, he'll replace it with whatever, no problem, money back, etc. So I was wondering what the forum's take on this carb is, if anyone had experiences with it, or if you have one right now that you love or hate. I guess my other option is a Demon for like $100+ more, or telling him to just have the E/B Q-jet anyway. My mechanic is a big E/B lover, and an even bigger Holley hater, which is fine, cuz I'm no big fan of Holleys. Now remember, this for street perf and normal use, not strip or racing or things like that.
Re: Edelbrock Thunder Series AVS?? (RedBlazed)
ttt, would really like some advice on this, and this forum is the best place for that.
Also, I'm now reading about CraneCams ignition stuff, how much better is it that the MSD 6AL and MSD tach-drive dist I'm having put in right now?
for what it's worth my mechanic has the exact same feeling about the Edelbrock carb and the same disdain for Holley carbs.
I don't know if he's right or not but I ordered mine and it's coming Monday. :party: I didn't want to go with the Holley because of the potential for leaks. What I really wanted was a carb that I could just bolt on and go with. Also, the Edelbrocks seem a lot easier to set up because you don't have to drain them and take everything apart everytime you want to make an adjustment. JMHO, I hope I'm right.
Cruise-In III Veteran
They're a slightly upgraded version of the Performer line. I for one really like the Edelbrock carbs. Easy to set up and worry free.
One thing to keep in mind, in my experience, and most others, they tend to be a bit rich out of the box. Drive it and test before you make any changes. But you might find yourself going a stage or two leaner than delivered
Also, watch your fuel pressure. Typically they don't like more than 6 psi. Higher fuel pressure will overcome the needles and waste a bunch of gas. I put a fuel regulator in line, with port 2 taking the excess to the return line.
Re: Edelbrock Thunder Series AVS?? (biltogo)
Thanks for the added info on its richness and fuel pressure needs. My mechanic will be doing all the configurations and testing before I get my car back.
I was more or less trying to get a feel for how it performs and its fuel efficiency and reliability when compared to like Holleys, Demons, and Q-jets. That type of thing if anyone has any experience or article links with that...
