Where can I buy these clips?
I am looking for these antenna wire/wire harness clips online and I can't seem to find them anywhere. Doc Rebuild has them but they are not in stock and won't be for a couple of months. The clips in question are along the door sill and are different size than the ones behind the dash. One of mine had broken, and the other one is so work hardened that I think it is gonna break as well if it is bent open and closed too many more times. Anyone know where to get new repros? :confused:
AC
AC
Re: Where can I buy these clips? (A C)
I don't know where to buy 'em - but I have an idea to make some:
There are basically a piece of rubber coated sheet metal.
Find an appropriate piece of sheet metal at your local hardware store.
Find a can of that vinyl dip - that you coat plier handles with - and you can
have a whole car load of 'em for a few bux.
:seeya
:seeya
Re: Where can I buy these clips? (NHvette)
I will try the first idea, and if I don't find them there, I will try the second idea. :D
AC
AC
Electronic supply stores sell plastic wire holders with a screw hole on one end. They come in many different sizes and since they do not show anyway
are a functional alternative. A small package of them will be less than
$5.00.
[Modified by mark79,80, 7:21 PM 2/28/2003]
$5.00.
