Whileimatit strikes again.
Since I am putting new rotors and calipers on and have to have the hubs turned on a lathe, I might as well install new lugs and bearings.
Oh, and I might as well switch to the faster steering position on the arm.
And since that needs an alignment anyway, I might as well redo the tie rods and lower the car...
Does it ever end??
Does it ever end??
Re: Whileimatit strikes again. (70 LS1)
Does it ever end??
Does it ever end??
BTW, if you go with 3" Moroso lug studs in 7/16" x 20 and the .480" knurl, you might very well have to enlarge the holes. I forget exactly the spec, but I found a 12mm drill was right in the middle of the spread.
Good luck.
