ZZ4 valve cover question.
If I were to take a new ZZ4 and change the rocker arms requiring a taller valve cover(center bolt), what covers would you guys recommend????
Thanks in advance. :)
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: ZZ4 valve cover question. (71,454,4spd)
I've read in Chevy High Performance that one of the best buys for a ZZ4 is the GM Performance Roller 1.6 rockers. They will fit under stock center-bolt covers without mods. These are self guiding rockers which is a necessity with ZZ4 heads. If you use anyone else's roller rockers (non-self aligning) then you'll have to run guide plates.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: ZZ4 valve cover question. (Smokehouse69)
I don't know of any tall centerbolt vavle covers, or a need for them.
You could, at big expense, use the center bolt to standard valve cover conversion kits. But at $160 just for the kit, I would have to ask "Why?"
